Hello all,
I recently got a Canon SX1 which records HD video (1920x1080) and saves as .MOV (Quicktime MPEG-4) files. The files are huge, as you'd imagine (a 9:18 clip is 2.8GB).
Right now, I'm trying to get these clips onto YouTube at the highest quality possible. This is fine with files that are under 1GB, as I can just upload the original, but what's my best bet with a file like the one I mentioned above, at 2.8GB? How can I get that down to 1GB without completely destroying the quality?
I've been using MPEG StreamClip with mixed results. I'm finding it hard find a way to get the filesize down. Reason I mentioned AutoGK is because probably my favorite feature of AutoGK was you could just tell it what size file you wanted it to output, and it took care of the rest. Is there a program out there that will do this with my HD .MOV files? And if not, what's my next best bet?
Thanks in advance.
Doesn't it work with AutoGK?
EDIT: Oops. I was thinking of AutoMKV. Nevermind. AutoMKV is an outstanding application, but I don't recall an ability to specify output size. Still, the .MP4 output is great looking.
Regardless of what you end up using, 1280x720 at 4500Kbps would be the maximum resolution you'd need to upload to Youtube. Anything more would just be a waste of resolution and bandwidth. That will give you around 22-27 minutes of video for a 1GB output file at the above resolution at CBR with 320Kbps audio. -
awesome! thanks, Baldrick!Originally Posted by Baldrick
i've seen it mentioned around here, but honestly, the name made me think it wasn't what i needed. great program!
How to include IFO files with .VOB into AutoGK?
By reysaj in forum Video ConversionReplies: 4Last Post: 1st Dec 2010, 09:27 -
How to join back 2 xvid files encode by autogk
By warresg in forum DVD RippingReplies: 1Last Post: 6th Nov 2010, 02:59 -
Wrong File Size on Ripped Files using AutoGK
By tommyjv in forum DVD RippingReplies: 4Last Post: 17th Nov 2008, 12:21 -
Strange AutoGK output files
By bennyboy371 in forum DVD RippingReplies: 7Last Post: 14th Mar 2008, 08:21 -
How does AutoGK work for making SVS to avi files?
By loninappleton in forum Newbie / General discussionsReplies: 0Last Post: 9th May 2007, 14:04
