I've been using VirtualVCR to capture from my video cam for a long time with no dropped frames or any other problems. I was using an ASUS P5NSLI mobo with 1gig ram and a Pentium D 3.4 gh proc.
I recently switched to a P5QL PRO mobo (same ram and proc) and since the switch VirtualVCR is dropping frames at an insane rate.
I have 2 SATA drives and 1 IDE and it drops frames on all drives.
Any advice would be greatly appreciated, thanks.
Could someone lend a hand here, I have an ATI 650 pro cap card and for some odd reason I'm dropping 33 frames every 5 secs. I'm puzzled
if you got a video card with audio inputs (it's trendy these days)
you best connect your wires directly to you audio card to avoid dropped frames
As for Virtual vcr there are options in the audio tab to solve the issue (resample dynamically seems the best way)*** DIGITIZING VHS / ANALOG VIDEOS SINCE 2001**** GEAR: JVC HR-S7700MS, TOSHIBA V733EF AND MORE -
This doesn't help, I never run my audio through the cap card but into the line in on the audio card. I have a 650 and a 550 and neither work in this recent motherboard (P5QL PRO), I was just hoping someone else had encountered this problem and had a solution.
Little setting problems with VirtualVCR
By Greycat in forum Capturing and VCRReplies: 10Last Post: 28th Jul 2015, 18:07 -
VirtualVCR cap fails in virtualdub...
By Asesinato in forum Capturing and VCRReplies: 36Last Post: 12th Apr 2012, 11:43 -
VirtualVCR Tweaker
By Torrential in forum Capturing and VCRReplies: 1Last Post: 21st Apr 2010, 04:24 -
Trying to use VirtualVcr with Leadtek Tv2000 expert.
By GLE3 in forum Capturing and VCRReplies: 0Last Post: 20th May 2009, 09:46 -
VirtualVCR and ATI TV Wonder
By moorthy in forum Capturing and VCRReplies: 1Last Post: 28th Sep 2007, 18:46
