Can anyone recommend a recording program, which can record longer than the normal windows sound recorder, as I play guitar and want to record it on the PC something which can maybe record a whole hour
Buy My Books -
There's a trick you can do with the Windows sound recorder. Open a long WAV file (longer than you want to record). Set the mark in point at the start. Now you can record for as long as the WAV file. If you don't have a long WAV file sitting around just start recording one. When the sound recorder stops hit record again. It will append another minute or so. Do this repeatedly until you have the length you want.
Audacity is free, can record for as long as you want (or until you run out of memory), has lots of audio processing filters, and can save as WAV, MP3, etc. -
Audacity is very good and very powerful.
If you're going to do any post-processing, mixing, etc it's a good choice.
Alternatively, MP3DirectCut can record directly to MP3 (at any bitrate if you install Lame).
Both are freeware.
Recording program that creates already compressed videos
By Crimson in forum Video Streaming DownloadingReplies: 2Last Post: 25th Apr 2011, 10:02 -
recording program
By west403 in forum Capturing and VCRReplies: 0Last Post: 12th Sep 2009, 22:49 -
Which program do you use for mpg2 tv recording ?
By WinSpecToR in forum Capturing and VCRReplies: 10Last Post: 11th Jan 2009, 00:06 -
Did you see any reliable MP3 recording the FM stereo program?
By coody in forum AudioReplies: 1Last Post: 30th Nov 2008, 21:33 -
Erase/record new program from *middle* of previous recording?
By NoahsMyBro in forum DVD & Blu-ray RecordersReplies: 10Last Post: 18th Nov 2007, 12:55
