Results 1 to 11 of 11
  1. Can anyone recommend a free program that rips / converts the audio from a DVD to either .wav or .mp3 files?
    I have done the usual searching but only found some shareware programs that are designed to do mostly other stuff that I'm not interested in. Thanks.
    xvid4psp, open dvd, audio->save to wav.
  3. Originally Posted by Baldrick
    Thanks. I tried different versions of this program. Unfortunately they either crash, or won't install with Win98.
  4. Member ranchhand's Avatar
    Oct 2005
    USA-midwest
    If you are still using Win98, I respectfully suggest you seriously consider upgrading. You are going to face a lot of disappointment and frustration in video/audio editing with modern formats trying to use DOS based OS.
  5. Member olyteddy's Avatar
    Dec 2005
    If you're still using Win 98 I'd suggest you populate your 'Computer Details' section...
    Croatia
    With Win98 use:
    VOBEdit to extract (demux) audio from DVD. It will be in AC3 format.
    To convert AC3 to WAV use:
    - PX3Convert AC3toWAV which you can download here: http://www.digital-digest.com/software/download.php?sid=12&ssid=0&did=1
    - or BeSweet which will convert AC3 in any other audio format.
    - or HeadAC3he.
    Those are all little freeware tools easy to use.
  7. Originally Posted by Jeremiah58
    With Win98 use: ... Those are all little freeware tools easy to use.
    Download, installation and doing a project took only mintutes and worked perfectly. Thanks for your very helpful reply!
  8. I'm a MEGA Super Moderator Baldrick's Avatar
    It would have helped if you told us FIRST that you used win98...
  9. Originally Posted by Baldrick
    It would have helped if you told us FIRST that you used win98...:)
    I didn't think of it at the time since about a dozen or so other DVD processing programs I am using work fine under Win98.
    But you are right -- in 2009, running Win98 should be mentioned when making any inquiries, so I apologize!
  10. Member olyteddy's Avatar
    Dec 2005
    You might find something appropriate here: http://www.oldversion.com/
  11. Originally Posted by olyteddy
    Interesting resource. Thanks for the link!
