I have a DVD-RW which i recorded from my DVD recorder. Of course, the recorder encoded the audio in AC3. I need to edit the DVD, to take parts out of it, and i have no software which will decode AC3. I need to first convert the audio to mp3, and THEN re-encode everything so i can put it back on DVD.
what's a good way to do this?
thanks
	You could use a dvd editor that supports ac3 like VideoRedo, Tmpgenc DVD Author, Mpeg Video Wizard.
 Or if you want to convert the audio to mp3 or better wav lpcm you can use avidemux, open the first VTS_01_1.vob(1GB) from the DVD and it should open the entire DVD. Under video choose copy and under audio set it to wav lpcm. Save as a MPEG-PS and when saving save as video.mpg. You can now try edit the mpg file.
  How will an MP3 audio file will compare with a AAC audio file?By ConverterCrazy in forum AudioReplies: 6Last Post: 31st May 2011, 03:01
  Sony Vegas Pro 8.0 : Problem to encode audio file into mp3.By flash_49 in forum Video ConversionReplies: 0Last Post: 20th Jul 2010, 07:21
  MPEG2 Video with AC3 audio cannot convert to MP3 audioBy wenglock in forum ffmpegX general discussionReplies: 0Last Post: 7th Sep 2009, 22:52
  Converting or Muxing audio files (mp3 etc.) into MPEG2 TS without any videoBy kary.sharma in forum AudioReplies: 1Last Post: 5th Dec 2008, 10:43
  Passthrough mpeg4 video but re-encode mp3 audio to AAC?By live4ever in forum ffmpegX general discussionReplies: 5Last Post: 8th Sep 2007, 11:56
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
 Quote Visit Homepage
				Visit Homepage
