I have a file with two different audio tracks. one track is japanese and the other track is english.
whenever I try to convert I ALWAYS end up with the japanese track in the AVI but I want the english track as audio
IS there a converter that lets me choos which audio track it will encode to the AVI file???? if so tell me name and give me link
thanks
One way to do it is to delete the audio stream/track that you don't want (backup your file, first), before feeding it to your converter. For OGM, you can use VirtualDubMod, go into the Streams List, then disable the audio track. If you want, you can also change the compression settings and have VDubMod save the video to an AVI (most OGMs I've seen are usually just an Xvid-compressed AVI video stream with separate Ogg-format audio streams.)
For MKVs, I believe you can use MKVMerge, from the mkvtoolnix pack.If cameras add ten pounds, why would people want to eat them?
Converting Multiple Audio Track MKV's to avi without Quality loss
By OrtegaSeason in forum Video ConversionReplies: 4Last Post: 6th Feb 2011, 08:09 -
How to make Dual audio on mkv video without converting to AVI
By Aboudi09 in forum Video ConversionReplies: 9Last Post: 21st Jul 2009, 14:17 -
FFMpeg Dual Audio MKV/OGM Non Monotone Timestamp
By blazerqb11 in forum Video ConversionReplies: 8Last Post: 25th Jul 2008, 16:36 -
Dual Audio .ogm/.mkv to dvd
By aszwet1 in forum Newbie / General discussionsReplies: 1Last Post: 10th Jul 2007, 20:35 -
Dual audio .mkv/.ogm to DVD
By aszwet1 in forum Authoring (DVD)Replies: 1Last Post: 10th Jul 2007, 19:12
