  1. Has anyone tried it ??? I have been trying to do a 1hr 30 min rip of the image file i made onto a cdr for 12 hours now ??? just seems to be hanging ?
    Help !!!!!!!!!
    Feb 2002
    michigan
    Yes i've tried it the demo version and the audio was out of sync decent picture though.
    I use a prog called dvd2svcd now though done about 10 movies now and the quality is exellent!!!!
    If you are intrested go to doom9.net and read it is free but the encoder he use is cinema craft encoder and it is really expensive all i can say is do a search for the program.
  3. Cheers mate off to give it a try ....i have the cinema craft encoder with the crack codes if you don't have it mate ....off to give it a try .
  4. ***Do NOT ask for warez, give warez or link to warez***
    edited by Truman
