This may be simple, but am new to vdub. I am trying to take several small avi files and combine them into one file, as well as cut sections out of large avi files and paste them into other avi files. Is this possible with vdub. if not what program is recommended.
Yes, it's possible, but all the AVIs you expect to join have to have the same properties - codec, resolution, audio format and bitrate, sample rate, etc. Since it sounds like you're combining a bunch of unrelated videos my guess is that you can forget the idea unless you're prepared to reencode them so they do all have the same properties.
If all the vids meet divx home theatre profile and have abr or cbr mp3 audio, you can use DivXMediaBuilder to combine them into one .divx file with a menu that will enable you to select any for playback and if you start from the first will play through all. You will need divx codec installed. the .divx file will play properly in DivX player and windows media player.
advantage- the files need not match in resolution and audio bitrate as long as they meet divx home theatre profile
disadvantage- no way at present to extract any but the first avi file from the divx file.
Join or Combine 2 AVI files with no quality loss.
By deadnuttz in forum EditingReplies: 18Last Post: 21st Sep 2016, 03:09 -
How would I combine 2 avi files into one?
By Variable in forum Newbie / General discussionsReplies: 7Last Post: 27th Sep 2010, 17:50 -
Combine/Merge two avi files
By motherwell in forum MacReplies: 4Last Post: 28th Jan 2010, 16:45 -
AVI files are too small when copied to a DVD
By lmcnlcy in forum Newbie / General discussionsReplies: 4Last Post: 15th Mar 2008, 01:44 -
my avi files appear too small on tv...
By vinayak1986 in forum DVD & Blu-ray PlayersReplies: 7Last Post: 23rd Dec 2007, 19:48
