I am attempting to rip a DVD (non-encrypted) but and having trouble with bad sectors. I can't get past a specific point with either my DVD player or my burner (playing and ripping). There are not chapter marks to allow me to just past the problem point. Are there any packages out there that might help this? I have used Nero without success. I can live with getting static or similar for the bad areas but want to at least be able to continue past that point in the DVD.
See if the disc is dirty or scratched. If it is scratched you can buff the disc to get rid of scratch, check youtube or google on how to do it safely. If it has a bad burn you are out of luck on that disc. When you are reading that disc to HD you have to set "ignore the errors" on the burner to get the rest of it. Since it is not encrypted you can also copy and paste each vob until go get to the bad one.
The disc is a commercial disc without encryption so I assume that means pressed not burned. There are little or no scratches visible and I have tried to clean without success. Will look at ISOBuster and Puzzle. I have identified which VOB it is but so far that does not help. For those that might wonder, I am trying to watch part of what is on the disc and not trying any type of piracy. My hope is to get by the "bad sectors" so I can watch the end of my video. I don't even have to burn whatever I get from any software. I am content with watching the end from my computer if that becomes possible.
From the problem you are describing....my guess is that youOriginally Posted by AlfB
are wrong about the disc not being encrypted(or protected).
Mactheripper bad sectors when burning Disney movies
By TXMacUser in forum MacReplies: 10Last Post: 8th Feb 2010, 17:16 -
How to repair dvd with corrupt sectors AND bad video_ts.ifo?
By Spixe in forum Authoring (DVD)Replies: 8Last Post: 25th Jan 2010, 08:54 -
bad sectors/clusters
By stompinne in forum Authoring (DVD)Replies: 7Last Post: 17th Sep 2008, 15:13 -
Bad Sectors?
By whoisquilty in forum MacReplies: 8Last Post: 19th Apr 2008, 21:09 -
Bad Sectors..
By SE14man in forum Newbie / General discussionsReplies: 10Last Post: 14th Sep 2007, 12:06
