HELLO
I have k-world dvd maker usb 2
i need to capture video in hd using VirtualDubMod\
so how can i do it?
thanks
You probably can't. You usually have to use the software that comes with USB capture devices. Other software can't deal with them.
Does k-world dvd maker usb 2 even capture in HD, or is it a standard definition device ?
Edit : It can't. It has a max. resolution of 720 x 576 (PAL) or 720 x 480 (NTSC). All SD level stuff. If you want o capture in HD, you will need a much better piece of kit than anything from k-world.
And looking at your very vague computer details, probably something much faster that you currently have.Read my blog here.
fine , but i tried to capture from virtualdubmode and it worked but i need it to be high quality
High quality comes from the codecs you use, the way you configure them, and the amount of power you have to support these settings.
High quality requires either very little compression (big files) or a very fast machine. The k-world device you are talking about can (according to it's website, anyway) encode directly to mpeg-1, mpeg-2 or mpeg-4 itself. If it can do this with it's own hardware then you will probably get better quality and smaller file sizes than you can get using virtualdub.
If you insist on using virtualdub for your own reasons, use a lossless codec such as huffyuv or lagarith (at around 30+ GB per hour), then re-encode afterwards using high quality settings. Generally the higher quality settings require 2-pass encoding, which cannot be done at capture time.
if you want more specific help, try providing some real details about what you are doing. Things such as
What resolution are you capturing at ?
What is your source ?
What codec are you using ?
What settings ?
What is you CPU (find this by right-clicking on My Computer and selecting Properties - it will tell you on the main tab) ?
Perhaps even an explanation as to why it must be done in virtualdubmodRead my blog here.
Help Finding A High Quality Capture Card
By NMeade in forum Capturing and VCRReplies: 4Last Post: 24th Apr 2010, 21:00 -
Need new ideas to Capture Video game footage at high quality
By APFable in forum Capturing and VCRReplies: 3Last Post: 5th Aug 2009, 20:27 -
How To Capture PC Video In High Quality To DVD And Blu-Ray Disc
By blazin-j in forum Newbie / General discussionsReplies: 15Last Post: 23rd Oct 2008, 08:33 -
Seek High Quality Capture to MPEG4 Service Provider!
By bradeso in forum RestorationReplies: 3Last Post: 25th Aug 2008, 12:59 -
By bradeso in forum Capturing and VCRReplies: 0Last Post: 25th Aug 2008, 12:03
