I occasionally use my Samsung television as a computer monitor. To get the display from the computer to fit the screen I have been using the P-Size button to switch from 16:9 to Just Scan. When I select Just Scan, the picture fits fine, but after about an hour it switches back on its own to 16:9, which clips off the edges of the picture. How do I get it to stay formated for my computer.
If this is the wrong forum, or not an appropriate question for this community I appoligize. I found this forum when I was doing a search for the answer. Thanks in advance for any help.
I have an older Samsung model and it doesn't have that problem. It stays where I put it (just scan, 16:9, etc). I would check for a firmware update from Samsung.
You might have better luck finding information here:
http://www.avsforum.com/avs-vb/showthread.php?t=1007540 -
Thanks for the reply. I looked over that thread and did not see anything about my problem.
I know how to update drivers, software ect on a computer, but don't have a clue about how to update firmware on a television. -
It's pretty easy but you'll have to check the specifics of your TV. In general, you download the file, put it on a USB thumb drive, then put the drive in the USB port on the TV. You may have to navigate through the menus and elect to update the firmware.Originally Posted by hammec
Thanks. Sounds simple enough. I had visions of myself with a magnifing glass and soldering gun.
Region 1 Samsung dvd-vr375 to switch to region free
By catleo in forum DVD & Blu-ray PlayersReplies: 3Last Post: 27th Dec 2011, 11:25 -
How do I make my Samsung R150 recorder region free? I have the code to make
By charpee in forum DVD & Blu-ray RecordersReplies: 2Last Post: 26th Jan 2008, 07:10 -
display problem switch from pc to tv, can't switch back
By samiam5156 in forum ComputerReplies: 1Last Post: 11th Oct 2007, 10:23 -
Samsung DVD-V6700 (US) make them multi region ?
By suAve in forum DVD & Blu-ray PlayersReplies: 5Last Post: 11th Sep 2007, 08:48 -
What might make Windows switch a DVD drive to non-DMA mode?
By EddyH in forum ComputerReplies: 8Last Post: 1st Jul 2007, 23:35
