I'm so new at this it isnt funny....this is my issue:
Archos requires you to purchase plug ins to play videos..So I found away around by converting .flv to mpeg and using windows movie maker to put the video on my computer then sync to my archos..latley after converting to video it just freezes after 2 min in...
There has got to be an easier way:: I know I'm making this way to hard on myself.
Any sugestions?
	Is it freezing during the conversion or during the transfer?
 I have the Archos 604. I use TMPGEnc 4.0 Xpress to handle my conversions. I usually convert to .divx. Archos 604 plays .divx natively. You can try that format. I NEVER transfer by syncing. I just setup the Archos as a hard drive and transfer that way.
 Brainiac
	Thanks for your info I will try this..I knew there had to be a better way
  Video files for an Archos AV 500By merryperson69 in forum Newbie / General discussionsReplies: 1Last Post: 31st Dec 2009, 07:08
  Archos 605 Video EncodingBy DJboutit in forum Video ConversionReplies: 4Last Post: 27th Dec 2009, 15:38
  [Archos 605] transform from 720p.HD.DVDRip.XviD.AC3 to Archos format ?By birdwing in forum Portable VideoReplies: 2Last Post: 6th Nov 2009, 00:41
  newbie archos 402 video questionBy brucey2 in forum Portable VideoReplies: 0Last Post: 28th Dec 2007, 05:28
  Archos 404 & DVR stand vs Archos AV 500 - difference in MPEG-4 recordinBy DavidMcGowan in forum Capturing and VCRReplies: 0Last Post: 4th Aug 2007, 06:49
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
