Using the Gunnar Thalin Deshaker plugin, I find I sometimes get top border intrusion on the final avi even though I've got "Fixed zoom no borders" chosen on pass 2. Trying to determine why sometimes it does it and sometimes it doesn't.
Any suggestions ?
Thanks for all input.
maybe your source is flubbed right there
whats the destination?
if tv, the overscan will hide it
make sure to check "use preceeding frames to fill" or somesuch
I suppose you could zoom in a tiny amount on these otherwise
while others haven't had much luck with this ap, I've had great success when I went bonkers and didn't use my tripod for a short while
I'm much better now... -
Originally Posted by zoobie
Well, I couldn't get rid of it before and now I can't re-create it. I think it has to do with some minimum values in the correction parameters in Pass 2, or some other setting that I changed without paying attention.
Top & Bottom border
By burgin in forum Newbie / General discussionsReplies: 1Last Post: 9th Jun 2011, 19:31 -
frame freeze when I use Deshaker plugin
By Cazz in forum EditingReplies: 1Last Post: 28th Jul 2010, 07:31 -
VDUB, deshaker, output(compression) problem
By zzyzx2 in forum Video ConversionReplies: 2Last Post: 28th Apr 2010, 01:47 -
Vdub Thalen Deshaker Gets To Certain Point And Stops
By brassplyer in forum EditingReplies: 0Last Post: 31st Dec 2009, 08:12 -
Granularity in image when using deshaker in Vdub
By brassplyer in forum RestorationReplies: 2Last Post: 24th Dec 2009, 00:47
