    Jan 2009
    Turkey
    Moving scenes of video gets like this, i'm using autogk. I tried with different tools. Only Kingdia Ripper solved it but it crashes at the half of ripping. How i can fix this in autogk or with xvid's or divx's configuration screen.
    Source video
    Video
    Format                           : MPEG Video
    Format version                   : Version 2
    Format profile                   : Main@Main
    Format settings, Matrix          : Standard
    Duration                         : 21mn 32s
    Bit rate mode                    : Constant
    Bit rate                         : 5 215 Kbps
    Nominal bit rate                 : 9 800 Kbps
    Width                            : 720 pixels
    Height                           : 576 pixels
    Display aspect ratio             : 4/3
    Frame rate                       : 25.000 fps
    Standard                         : PAL
    Colorimetry                      : 4:2:0
    Scan type                        : Interlaced
    Scan order                       : Top Field First
    Bits/(Pixel*Frame)               : 0.945
    Audio
    Format                           : MPEG Audio
    Format version                   : Version 1
    Format profile                   : Layer 2
    Duration                         : 21mn 32s
    Bit rate                         : 224 Kbps
    Channel(s)                       : 2 channels
    Sampling rate                    : 48.0 KHz
    Resolution                       : 16 bits
    Apr 2004
    Miskatonic U
    Rip to the HDD first. If it is protected, use DVDFab HD Decrypter. If it isn't protected, try a straight copy first, or use DVD Decrypter (it still has it's uses).
    I have not seen AutoGK do this when I have used it, but a few things check.
    Are you running the latest version of AutoGK ?
    Are you running a recent version of Avisynth ?
    Are you running a recent version of the Xvid codec ?
    Read my blog here.
    Jan 2009
    Turkey
    DVD is already in HDD AutoGK is v2.45 Avisynth and Xvid Codec came with AutoGK. I tried Divx with AutoGK but the result is same. I tried with Super DVD Ripper and the same result again
    Apr 2004
    Miskatonic U
    Post a shot from the source.
    Also, try Xvid4PSP.
    The issue appears to come form poor resizing of interlaced material, however AutoGK usually does a pretty good job at handling that situation.
    Read my blog here.
