Hello ,hope some can help.I have a new cell phone that has a micro sd card in it.I have converted a dvd movie to mp4 format to place on the sd card and watch on the phone.I used dvdfab and the conversion went great.So i believe.When i play the movie on the phone the audio is great but the video lags behind by quite a bit.The phone is an lgcu515.Not sure if this is due to the phone and is considered normal or the conversion went bad.The sd card is 2.0gig.I`m thinking the phone memory is not enough to handle the movie.Any help would be appreciated.Also the movie conversion resulted in a file of 310.mb stored on the sd card.
Thanks for your response.I did use the dvdfab to cell phone setting but my phone did not show up in the list to configure.So i chose the next in line that showed mp4 format and there are several.As far as bitrate i did the automated thing but i see on the sd card instruction it shows it needs a bitrate of 384kbps for mp4.I tried chaning that setting and it will not accept it.It changes it to 38 instead of 384 when i input that number.I will try the one that you advised and see how that works.The aspect ratio i believe is also automated.
Want to copy a DVD Movie in Cell Phone !
By augustya in forum DVD RippingReplies: 11Last Post: 25th Sep 2010, 05:46 -
DVD to iPoD/PSP/Cell phone/PCP including subtitles using DVDFab Platinum
By Baldrick in forum User guidesReplies: 6Last Post: 14th Nov 2009, 14:09 -
Converting DVD'S to a Samsung Cell Phone
By bigjimmpls in forum Video ConversionReplies: 2Last Post: 6th May 2009, 08:15 -
dvd to cell phone quality question
By m-man in forum Portable VideoReplies: 2Last Post: 24th Jun 2007, 00:18
