Hi,
I have decided to redesign my home audio/video setup to save the hassle of constantly reconnecting wires. I ordered the parts and put it all together, in the end I need to manually re-plug the wires to switch between Mode A and Mode B.
Everything works great with Mode B, but my problem lies with Mode A and the projector.
There are constant horizontal lines that are moving upwards and the screen will go blank for 2 seconds out of every 20 seconds.
My initial guess is that the 50' cable was killing the current, so I tried a 30' cable. Unfortunately that didn't fix it.
I also tried taking Mode A and bypassing the switch, directly into the Cable Box. Again, same issue. A friend suggested that the VGA Gender Changer could be introducing a lot of static, but I figured I'd post here before ordering anything new.
Any ideas as to how I can fix this problem?
Thanks!
Dimava
Results 1 to 1 of 1
check out my setup and let me know the problem
By thedude4242 in forum Authoring (DVD)Replies: 1Last Post: 16th Feb 2011, 16:20 -
new HD projector
By mgrig in forum Newbie / General discussionsReplies: 2Last Post: 23rd Apr 2010, 13:01 -
Foxconn motherboard design setup problem...
By MidnightMike in forum ComputerReplies: 3Last Post: 19th Feb 2009, 10:33 -
Projector Problem: Some videos smooth motion, others have "tearing&qu
By Xenogear900 in forum DVB / IPTVReplies: 16Last Post: 27th Jul 2008, 22:54 -
Pioneer DVR-531H-S Setup Problem
By christopheramos in forum DVD & Blu-ray RecordersReplies: 2Last Post: 5th May 2008, 16:43
