My partner has just bought a iPod Docking Station for £40 - it was reduced from £80 at Tesco's
out of box it was clear it was a return as there was slight marks/scratches....
it has 2 x 10w speakers and a 20w bass speaker in middle....
now, the problem is when the backlight is on (on the nano) and the ipod nano is changing anything on screen it cackles and stuff as if its picking up interference from the ipod? now it ONLY happens whilst the backlight is on - when the backlight goes off and it still changing the time and name on screen it DOESNT make the noise...(which can only be heard in silence or low sound) - once you choose and album and let it play its fine but they (Tesco) have none left and you cant get any as near as powerfull for same price so we are looking for a fix if anyone can help....
its fine when my mobile phone is plugged into it via AUX proving its picking up from the iPod ONLY when backlight is lit...
is there anyway of preventing this?
thanks
	I would test with a different iPod first. It could be an iPod issue, and not the dock. Google is your Friend
	its the dock - it changes , sometimes it keeps doing it when the backlight is off - the only way to completely avoid it is plug in via 3.5mm jack but then the remote only works for volume and on/off weve tried everything even turning off all hardware and wifi and its still does it
  Ripbot264 iPod format will play on iTunes but won't sync to iPod/iTouch?By Riley007 in forum Blu-ray RippingReplies: 2Last Post: 31st Dec 2010, 01:04
  DVD Player with Ipod dockBy dusty2 in forum Portable VideoReplies: 0Last Post: 31st Jul 2010, 22:29
  File Converted by Handbrake (0.9.3) Using iPod Preset Won't Play on iPodBy GrayStrickland in forum Video ConversionReplies: 0Last Post: 8th Mar 2009, 21:56
  any Ipod experts? way to restore lost music on IpodBy scustalow in forum Portable VideoReplies: 2Last Post: 9th Jul 2008, 01:56
  Videora iPod Converter (DVD to IPOD)By Denman007 in forum DVD RippingReplies: 0Last Post: 15th Aug 2007, 20:06
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
