I've been looking around the forums and don't see my issue addressed; sorry if it's been discussed and I missed it. The problem is this: when I convert certain downloaded AVI files to DVD format using Toast 9, the disc image, and disc itself, play fine on my computers, but when I play them in a standalone DVD player, the video appears as a small (about 1/4 of the TV screen) almost square image at the top left corner of the screen. The file info in Apple DVD Player shows that the file is 720 x 480, 16:9 aspect ratio, all looks good. What gives? Thanks!
are you sure you selected DVD output?
...seems to be the behavior of a SVCD with a non-compatible DVDReader
(my 2 cents)
byeFor DVD, iPad, HD, connected TV, … iMovie & FCPX? MovieConverter-Studio 3 (01/24/2015) - Handle your camcorder's videos? even in 60p or 60i? do a slow-motion? MovieCam. -
Thanks for the reply. Yes, the output is definitely DVD, and both my standalone players will handle SVCD format anyway, so I don't think that's the issue.
md -
download mydvdedit
double-click on an .IFO file to open your disc in it
select your "VTS 1" (top left)
(middle bottom) select vertical slider "VTS 1"
…what is the "Resolution" of your stream? (give all informations too, maybe it can be usefull)
aspect ratio
By devdev in forum Video ConversionReplies: 5Last Post: 19th Apr 2012, 17:31 -
Aspect ratio help
By kkiller23 in forum Newbie / General discussionsReplies: 5Last Post: 27th Sep 2008, 07:21 -
16:10 Aspect Ratio
By SWBisbee in forum Newbie / General discussionsReplies: 4Last Post: 31st May 2008, 01:41 -
keep aspect ratio?
By Dunkan21 in forum Authoring (DVD)Replies: 1Last Post: 28th Jul 2007, 13:27 -
Aspect Ratio's
By AndySpring in forum Newbie / General discussionsReplies: 7Last Post: 23rd May 2007, 12:55
