I have two mpeg clips with different dimension, so presumably one or both clips need to be resized and re-encoded either before joining, or as part of the join (preferably the latter to save me the step).
I used to use Womble Mpeg VCR for this which worked great but I had to buy a new tower which had Windows Vista and I can't seem to get Womble to work on this.
So can someone point out a Vista compatible tool I can get that will do this for me?
I checked the search section of this site and there wasn't a way (that I could find) where I could search tools on that criteria, this is why I must ask about it here.
Thanks in advance for the replies.![]()
mpeg video wizard.
Or a free solution, reconvert the first clip using avidemux(with same settings as the other) and then join using avidemux again.
Huffyuv+pcmaudio 2 clips = diff data formats?!?!
By duhmez in forum EditingReplies: 2Last Post: 19th Apr 2011, 20:48 -
Vista compatible mp3 editor which will save clips at 48kbps
By wetcamelfood in forum AudioReplies: 10Last Post: 17th Jun 2009, 17:39 -
Are any of these programs Vista compatible?
By magicfingers in forum DVD RippingReplies: 12Last Post: 7th Aug 2008, 20:04 -
Vista compatible?
By Slowburn in forum DVD RippingReplies: 2Last Post: 14th Jun 2007, 11:55 -
Vista compatible program?
By smudger2468 in forum Video ConversionReplies: 4Last Post: 31st May 2007, 17:09
