Here's my question: I have a "VideoHome GrabbeeX" usb-device. It gives a lot of formats to encode to, but not uncompressed avi. The best it can do is Mpeg-2, 720 x 576, 9000 kbs.
I would first like to have the material on my computer in as good quality as possible, and then start doing the necessary encoding. I have a lot of hard drive space, so that's not a problem.
If I first capture a tape at the settings mentioned above, and then, once I have the material on my computer, encode it again to Mpeg-2 (but with a lower bitrate to make the file smaller), how much does the final quality suffer compared to a situation where I had first captured the tape uncompressed?
I have been looking for a pci-e card that could capture uncompressed avi, but they are very hard to find. They all seem to have Mpeg-2 hardware encoding.
I just found out that "Hauppauge WINTV HVR-1100" can capture uncompressed avi. I can get it for 50 euros, which is not very much.
Does anyone have any experience about this card, and do you think it's worth buying? I wonder if the video and audio will stay in sync, since they will be captured with different devices?
Thanks! -
The "damage" depends on the content itself, the noise level, and the encoders used.
IME it varies between no visible difference, and a bit blocky/soft.
The compromise between 9Mbps MPEG-2 and lossless (100Mbps+) is to use DV (25Mbps).
Cheers,
David.
Sharp VCR (or similar) S-VHS quality for best capture of my VHS tape?
By ruehl84 in forum Capturing and VCRReplies: 0Last Post: 19th Feb 2012, 15:52 -
DV tape damage
By thedoingsful in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 13th Feb 2011, 23:19 -
25 Year Old VHS with Tracking Issues and Damage
By punkxdead in forum RestorationReplies: 8Last Post: 2nd Dec 2010, 20:58 -
How can VHS tape color loss be possible? ("tape fade")
By lordsmurf in forum RestorationReplies: 31Last Post: 18th Oct 2010, 09:32 -
DV tape damage during transfer
By syberkill in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 5Last Post: 22nd May 2008, 21:03
