Hi,
I'm downloading mpeg 2 files (.mpg) from www.archive.org and intend saving them as dvd's. I have iDVD and DVD Studio Pro, but they are geared up for .m2v files etc.
I can convert the .mpg files to lossless quicktimes and then jump through hoops to re-encode to .m2v files, but surely there is a simple means of converting a .mpg (mpeg 2 though) to a format that's acceptable without re-encoding?
If needs be I can use a PC for the process.
Any pointers?
btw: there are some lovely pieces of film on that archive.org site (various formats)
thanks.
You may be able to demultiplex your MPEG-2 downloads from archive.org by using bbDEMUX. It's available for Mac OS X.
Ta for that.
Demuxed a movie to create a new .mpg movie (I'd assumed it would create a .m2v file)
but when I import it as an asset in dvdstudiopro it throws a 'wrong width' error.
Any ideas?
Upgrading my system: Best approach?
By lamerc in forum ComputerReplies: 20Last Post: 17th May 2011, 05:52 -
Some help needed, Trying to find the best approach to edit MPEG
By chadwill in forum EditingReplies: 14Last Post: 21st Aug 2009, 07:45 -
Best approach to edit and reburn a home dvd?
By cr8250 in forum EditingReplies: 7Last Post: 14th Feb 2009, 22:25 -
Best Approach For Capturing Video Intended For Both DVD and Blu-Ray?
By blazin-j in forum Newbie / General discussionsReplies: 4Last Post: 2nd Jan 2009, 17:44 -
vhs avi to dvd, what is the best approach
By bati in forum Video ConversionReplies: 6Last Post: 11th Nov 2007, 23:37
