A lot of folks must be using nero; so maybe i can expect some help in regard of the above issue
When i input a video file to make a DVD or export it in another format etc - how do i know thew input file characteristocs such as frame size, frame rate etc from within Nero.
If not possible from within Nero which utility can give me these details so that i can set my export charateristics
g-spot or media info would be best, but there are others.
Can it be done from inside Nero - don't know. There are so many programs that do what Nero does, but are free and do them much better than Nero does, that I haven't had to use Nero in years.Read my blog here.
Output file is way bigger than input file in Virtualdub
By sasuweh in forum Video ConversionReplies: 31Last Post: 10th Oct 2013, 18:25 -
Input file is not an AVI file!... Uhhh, yes it is.
By joemacd in forum RestorationReplies: 3Last Post: 9th Apr 2008, 09:52 -
Subtitle Input string not correct format/Input subtitle file error (SOLVED)
By Webgirl in forum SubtitleReplies: 8Last Post: 13th Mar 2008, 09:59 -
WMV file as video input
By borntosucceed in forum Video ConversionReplies: 4Last Post: 25th Jan 2008, 18:48 -
Need input with convertx2dvd and nero 7's menu builder
By MidnightMike in forum Authoring (DVD)Replies: 4Last Post: 9th Nov 2007, 14:48
