I would like to burn the Olympics that I recorded in my DVR into DVDs but w/o the commercials. Can anyone suggest how I should do that best?
I'm thinking of burning them into a DVD-R in segments at a time then editing out the commercials in the computer then combining the main event from 2 DVD-Rs into 1.
But then I don't even know how to do that.
Thanks all
Sounds like you mostly need a MPEG editor. One method is to use a program to extract the MPEGs in the VOBs from the burned DVDs. VOB2MPG can do that. Then you use a MPEG editor to cut out the commercials. I would recommend something like VideoReDo or MPEG-VCR for a inexpensive solution. There are a few freeware MPG editors like MPEG Streamclip or Cuttermaran, but the payware programs may be easier to use.
Finally, author them to DVD format and burn. GUI for dvdauthor and ImgBurn are a couple of freeware ways to do that.
There are other programs and methods and others here may be able to give you some better suggestions.
Pioneer DVR-550H-s: transferring video from laptop to DVR's Hard drive
By anandmahey in forum DVD & Blu-ray RecordersReplies: 3Last Post: 30th Aug 2012, 06:38 -
Pioneer DVR-520H: seeking advice for DVR-107-XA drive replacement.
By donglejack in forum DVD & Blu-ray RecordersReplies: 71Last Post: 12th Feb 2012, 09:24 -
My first post: connrccting a DVD to a comcast DVR to record from ther DVR
By retired_guy in forum Newbie / General discussionsReplies: 10Last Post: 24th Jul 2011, 19:54 -
Pioneer DVR-520h or DVR-220 or DVR-225 replacement DVD-RW drive
By psymaster in forum Newbie / General discussionsReplies: 1Last Post: 31st Oct 2009, 20:48 -
By psymaster in forum Latest Video NewsReplies: 1Last Post: 31st Oct 2009, 18:26
