I like to get a capture card for my computer that will also export out to a VCR. However, the ones I am looking at (like the ATI All in Wonder for example) seems to require that the audio be looped from the capture card to the sound card and then out to the VCR. Which is not that bad execpt that what if your sound card does not have both line in and line out jack?
yea i have a all in wonder card and yea you gota do all that @#$% looping from the Sound Card back into the Videocard
well i think there is an "internal" solution to that
im not a tech wizard but i remember taking my tower to my boss where he just internally connected the two boards together
but i sugesst askin your "technical" friends take a look at it
oh geez and about your audio jacks and stuff ATI i think should have adapters so the Vidcard and take audio jacks in and capture and THEN that loop goes to the sound card so you can hear it.
but overall i think ATI is a good card to get
<font size=-1>[ This Message was edited by: timmy_boi on 2001-07-23 15:13:19 ]</font> -
I have downloaded the owner's guide for the ATI All in Wonder card and it shows that the while the audio/video from an outside source is inputed via RCA plugs, only the video output is via RCA plug. The audio has to loop into and then out of the sound card. It has nothing about doing the sound any other way. Unless you mean the CD in and out connections on the AIW board? But, I thought that was for something else.
yea i guess since we are talking about a "VIDEO" capture card and the quality of your sound will depend on the quality of your sound card.
Premiere Pro is exporting audio at -3dB
By Asterra in forum AudioReplies: 6Last Post: 11th Jul 2011, 19:38 -
Exporting video and audio as two different files?
By Luka38 in forum Video ConversionReplies: 6Last Post: 15th May 2010, 06:53 -
vegas exporting
By romanstopme in forum Newbie / General discussionsReplies: 8Last Post: 5th Apr 2009, 16:22 -
Exporting Windows Mover Maker Audio Files
By ProducerHarley in forum AudioReplies: 0Last Post: 12th Mar 2009, 17:41 -
Exporting audio from VideoStudio 9. Possible?
By markannab in forum AudioReplies: 2Last Post: 6th Jun 2007, 21:48
