Hi, I'm trialling this after realising that Ulead DVD Workshop 2 won't work on my new Vista PC (boo!), but while it does some things the same, it won't do others that seem so basic and it just seems so odd.
1. On the menu, I cannot simply delete unnecessary items within the menu at all, not even by pressing 'delete' on the keyboard.
2. There's also no 'undo' option for menu changes, eg. if you accidentally move something and want it back in exactly the same place (actually, as I type that I've just found I can right-click and 'reset selected objects' so that's some saving grace.)
3. When I create a new project, I can't give a title, nor is there an option to save it, so if I want to come back to it later I can't seem to do that.
4. Ulead DVD Workshop had the ability to just create an ISO so I could burn the disc later whereas this appears to just want to go ahead and burn it there and then (and I don't always want to do that).
These are things that are so basic that there's no reason why they shouldn't be there and it's very frustrating that they're not - unless I've missed some things within it.
Also, is there a way to import previous projects from Ulead DVD Workshop? Moviefactory just seems to have .dwz instead of .dws files and it won't let me select something other than .dwz
Thanks in advance,
	Dom Robinson
 Editor, http://DVDfever.co.uk
	(just had a quick tidy of my original post)
 I've since found out how to do No.4, as that comes up as an option on the screen where you go to burn the DVD.
 I can't figure out 1 & 3 for the life of me, though.
 Anyone know, please?Dom Robinson
	iirc, the save option is somewhere in the menus. It may be a good idea to look through ALL of the menus to find it.
 Brainiac
	Hi, thanks for that. Yep, I was a bit premature in my original post without looking too deeply into the menus.
 As I've had a further play with it, the fact that while I can save separate projects it only appears to save everything in one set of folders (rather than Workshop 2's individual ones per project - although I could keep a copy of each of these separate with some manual intervention), it only appears to give me one menu per project - whereas Workshop 2 would give you several although I only used a maximum of 4 on one DVD, and Moviefactory also crashed while I was previewing a DVD so, unless I'm mistaken, it seems like a poor man's Workshop (though the large difference in retail price can presumably account for that) and I can't understand why they dropped Workshop in favour of Moviefactory.
 I've seen the list of things Sony DVD Architect 4.5 can do and I'm thinking of giving that a trial run in the hope it does more that I'm after.Dom Robinson
  Adding 'copyright' info to video clip in Ulead DVD Moviefactory 6By colinb1 in forum EditingReplies: 3Last Post: 19th Apr 2011, 08:13
  Ulead DVD MovieFactory 6 Plus Menu Option QuestionBy SCDVD in forum Authoring (DVD)Replies: 3Last Post: 26th Jan 2009, 14:42
  Joining in Ulead DVD MovieFactory - does it lead to worse quality?By rosbif08 in forum EditingReplies: 2Last Post: 6th Aug 2008, 22:32
  Ulead DVD Moviefactory 5By Flying Doctor in forum Authoring (DVD)Replies: 2Last Post: 2nd Aug 2007, 11:43
  Questions about Ulead DVD MovieFactory 6By cheeseandcrackers in forum Authoring (DVD)Replies: 5Last Post: 18th Jun 2007, 11:46
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
