I have an AVI file that is a little over 2.3 gig and I would like to make it smaller. DVDShrink does not see the AVI file and I am unsure what else to try.
I installed this program but when I run it I get a error and it will not load my file. It tells me windows will look for a solution for the problem and then it closes.
Run the video file through a utility like GSpot or MediaInfo and post the information here. In the case of GSpot, you can post a screenshot of the resulting window. Blank out the file and path names, if you prefer. Maybe we can see if there's something about the file that Xvid4PSP definitely won't like, or that you'll have problems with, in general.
Also, how do you want to make the video smaller? Recompress with a different codec? Lower the bitrate or resolution?
Unfortunately, "(program) has encountered an error and needs to close" and Windows searching for a solution are just standard Windows crash error messages, for the most part. I'm not even sure it DOES search for any kind of solution.
Help: AVI compression using virtualdub
By stan101 in forum Newbie / General discussionsReplies: 9Last Post: 14th Oct 2011, 21:55 -
Error when saving from VirtualDub as AVI with compression
By Thread7 in forum Newbie / General discussionsReplies: 5Last Post: 9th Aug 2010, 21:41 -
ginormous avi (even after compression) What to do?
By hygieneboy in forum Authoring (VCD/SVCD)Replies: 6Last Post: 30th May 2008, 00:28 -
dv-avi(mpeg2) to avi compression
By nivek_nayr in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 11Last Post: 12th Feb 2008, 08:44 -
Best compression format for AVI's
By Smallan in forum Video ConversionReplies: 2Last Post: 19th May 2007, 18:13
