Hi everybody!
I try to denoise a HDV video. In the same script I try to compare different methods stacking vertically four results in the same window. One filtering script is too complex, so I tried to import it as tx.avsi. After I stacked between others this is the only one which is working, the other three only show the first frame in the whole video. Could be the problem that I used in the script tx the same Limitedsharpen and SeeSaw script also which is used in rect2 and rect4 lines? The script:
Or there is a simpler method to include scripts in another script?Code:SetMemoryMax(512) x=Import("W:\Video\tx.avsi").Trim(3868,4868)# a complex script Cropped to the same size like "rect" below MPEG2Source("V:\Capture-\video0002.d2v", idct=5, cpu=4) Trim(3868,3967) rect=Crop(0, 200,0, -610) rect1=x.Subtitle(" 1 - Complex Script") rect2=rect.Subtitle(" 2 - Limitedsharpen").LimitedSharpenFaster() rect3=rect.Subtitle(" 3 - fft3dfilter").fft3dfilter() rect4=rect.Subtitle(" 4 - SeeSaw").SeeSaw() StackVertical(StackVertical(rect1,rect2),StackVertical(rect3,rect4))
Results 1 to 1 of 1
DVD Lab Pro - Import .SSA subtitle problem
By satan999 in forum Authoring (DVD)Replies: 3Last Post: 27th Jan 2011, 07:21 -
Problem to import m2ts to Vegas
By Cazz in forum EditingReplies: 4Last Post: 14th Oct 2010, 11:20 -
Premier Pro Video Import Problem
By JojoTilly in forum Video ConversionReplies: 0Last Post: 3rd Jun 2008, 17:42 -
Problem to import video into windows media player 2.1
By Gilad in forum EditingReplies: 1Last Post: 5th Apr 2008, 14:22 -
DV import help
By VirtualDoobMon in forum MacReplies: 3Last Post: 4th Mar 2008, 01:34
