Hi all. I use a hard drive docking station, Thermaltake BlacX, to backup files and such. I was wondering if I should be storing my loose hard drives in a certain bag or container, or is it okay to leave them stored in a drawer uncovered?
Of course, the best storage solution would be the original packing material.
-In lieu of that;
It's probably too low-budget for some, but I've used quart size zip-lock bags.
For each bag, I've cut a 6.5" x 5" piece of heavy cardboard which is placed in the bag to protect the open side of the drive.
No drive failures ever, no problems experienced regarding paper dust, and the transparent bag makes it possible to see any label(s) identifying the drive's contents.
As I stated, perhaps too low-budget for some, but it's worked perfectly for me.THREADKILLER !
References on File. -
I store mine in an antistatic bag and in a clam shell package
Storing them unprotected isn't a great idea. You can easily scratch or break the mainboard or shock it without knowing.
I the past, I only used these. Just bought one case for each drive
Thanks for the tips folks. I shall use antistatic bags to be safe.
Storing & Playing Video from hard drive
By bertmartin in forum Media Center PC / MediaCentersReplies: 0Last Post: 4th Dec 2010, 11:24 -
Storing DVD's on an external hard drive
By avz10 in forum DVD RippingReplies: 6Last Post: 22nd Jan 2010, 10:47 -
hard drives
By Willy5157 in forum ComputerReplies: 7Last Post: 23rd Oct 2009, 04:16 -
2 hard drives
By danl_9x in forum ComputerReplies: 8Last Post: 8th Feb 2009, 22:55 -
Hard Drives
By jason in forum Newbie / General discussionsReplies: 7Last Post: 14th Apr 2008, 11:50
