Hello,
I just got my new x360 and i was wondering if it is possible to encode a MKV movie to a MP4 movie that can be played on the x360 without any qulity loss. I have tried GOTsent but i cant add subtitles i that tool. Then i have tried XviD4PSP 5.0, and it works really good but the files size i not so big as the mp4 file that GOTsent created?
Do i loose any quality when i use XviD4PSP 5.0?
Hope someone can help me
Regards,
r00t
MKV is not a blu-ray. Moving you to our video conversion section.
Yes, you will lose quality with xvid4psp (or any method when you add hardcoded subtitles). But you may not notice it though. You can adjust the file size by click on the E next the Video Encoding and change to the 2-pass size under Encoding mode. -
Okay. Is there any other way to add subtittle without any loose of quality?
Convert Mkv to Mp4 with subtitles to play on xbox 360
By Dreemer in forum Video ConversionReplies: 2Last Post: 14th Nov 2009, 00:21 -
Extract subs from MKV (MKVextract doesnt work) and Re encode to xbox 360
By Snipergod87 in forum Newbie / General discussionsReplies: 6Last Post: 6th Oct 2009, 17:51 -
Gotsent, sync problems MKV anime, dual audio and subs to xbox 360
By TheGlow in forum Video ConversionReplies: 2Last Post: 15th Apr 2009, 19:33 -
The Best Xbox 360 and PS3 mkv video converting to mp4 App.
By spyder7777 in forum Newbie / General discussionsReplies: 0Last Post: 11th Apr 2009, 04:55 -
MKV to MP4 screws up Anamorphic A/R xbox 360 playback
By mrdally204 in forum Video ConversionReplies: 0Last Post: 6th Dec 2008, 17:56
