I have some mini DV and mini DVD material and wants to edit and author some home movies.
Should I de-interlace the material during (or prior) to encoding to DVD format?
What are the pros and cons?
I always see that option on FFMPEGX settings and don't know what to do.
Material will be played on both new plasma tvs and old CRT tvs.
thanks
edit and author to what format?
if to dvd then no, as they are interlaced. -
MiniDV is true interlaced. Interlace and field order should be maintained throughout editing and encoding for DVD. I'm not sure what format MiniDVD uses, but I was always under the impression that it's already DVD compliant mpg2. As such you don't want to re-encode it at all, if you can avoid it. Either way, when going to DVD it is best to leave interlaced material interlaced and let the hardware sort it out.
Buy My Books -
DV would be bottom field first for editing and DVD encode.
MiniDVD is MPeg2 top field first (after demux from the VOB).
If you want to mix the two, I'd use a DV project setting and import the MPeg2.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about
Should deinterlace VHS captured material ?
By macmithos in forum MacReplies: 17Last Post: 5th Jan 2016, 11:56 -
Deinterlace first or multiple times? Encoding source to multiple formats.
By greyfalcon in forum Video ConversionReplies: 1Last Post: 12th Apr 2011, 05:39 -
Bad Xvid Encoding - forgotten deinterlace- Is there any way to fix it ?
By Womb4T in forum Video ConversionReplies: 1Last Post: 18th Dec 2010, 18:56 -
Shouldnt i deinterlace? (encoding with handbrake)
By squadjot in forum DVD RippingReplies: 3Last Post: 25th Sep 2010, 21:29 -
Encoding progressive NTSC material with Canopus Procoder 1.5?
By zee944 in forum Video ConversionReplies: 8Last Post: 13th Oct 2008, 08:56
