I want to burn a quicktime video file onto a CD or DVD because I am sending it to a film festival. Not for playing in a DVD player, but simply as data that can be dragged to another computer. I do it all the time with smaller files but this one is 22 gigs in length. None of the CD's or DVD's I know of can hold something that big. DVD's hold about 4 gigs but it's not enough. So my question is, are there special discs that can hold a lot more data?
Bluray, if you have a bluray burner. Otherwise you will have to either chop it up into smaller chunks, re-encode it to be much smaller, or use something like a large memory card or portable USB HDD.
If the file is DV then you could consider re-encoding it to H264, which will reduce the file size substantially while maintaining quality. Even a 90 minute DVD would be of good quality and would fit on a DVD5.
Of course it also depends on what the requirements are for the film festival. Some set pretty stringent conditions on the format of movies submitted.Read my blog here.
In some cases, they will accept files stored on a USB flash drive, so that possibly gives you another option. 32GB drives are now going for ~50-75 dollars, so it's not totally loony.
If the movie is only going to be viewed on a computer, why not just transcode it into H264 with a frame-size small enough to fit a single-layer DVD? Any (reasonable modern) computer with QuickTime installed will then be able to play it.
Avi file too large to burn to dvd
By MLPoison911 in forum Newbie / General discussionsReplies: 20Last Post: 12th Feb 2014, 13:07 -
large mp4 file to dvd
By GP_Wouter in forum Video ConversionReplies: 6Last Post: 3rd Nov 2010, 14:22 -
dvd help .size.file to large shouldnt be.
By larebow in forum Newbie / General discussionsReplies: 6Last Post: 10th Feb 2009, 01:08 -
Converted file too large for DVD.
By Dave H in forum SVCD2DVD & VOB2MPGReplies: 12Last Post: 18th Oct 2007, 19:08 -
How to get 14GB large mpeg-2 file to DVD?
By Bellman in forum Video ConversionReplies: 11Last Post: 20th May 2007, 19:38
