    Dec 2006
    Norway
    I am new to using Virtual Dub and I am trying to use it for editing a DVB-T stream as described here: https://forum.videohelp.com/topic356036.html
    Problem is that any file I feed into Virtual Dub, it only loads the first 920 frames (about 35 seconds) or so of the video... (even if the recorded .ts file is 2 hours long). I am just wondering if it's something very basic I am missing or if it has something to do with the format of the file (MPEG4, H264).
    Here is the avisynth script I am using:
    vid=DirectShowSource("J:\test.ts",fps=25,convertfps=true,audio=false)
    aud=wavsource("j:\test.wav")
    aud=DelayAudio(aud,.1007)
    audiodub(vid,aud)
    Load_Stdcall_Plugin("C:\Program Files\AviSynth 2.5\plugins\yadif.dll")
    Yadif(order=1) #top field first
    Crop(10,2,-8,0)
    LanczosResize(720,576)
    Trim(150,1072)
  2. Member gadgetguy's Avatar
    Feb 2002
    West Mitten, USA
    Trim(150, 1072)
    Do you understand what Trim means?
    Buy My Books
  3. Trim(150,1072): throw away frames 0 to 149. Keep frames 150 to 1072. Throw away any frames after frame 1072.
    Dec 2006
    Norway
    OK, thanks very much for the reply. I am still a noob at scripts and that line totally slipped my mind.
