I have 13 Avi files I want to put on one DVD to watch with a dvd player on the television. Most of the time I use FAV but this only does one avi per DVD disc. How do I get the most on to one dvd all if possible. Each file is roughfly 360,000kb
Ok so I select all the avi files for source video files, I do not see the running time option. I do see a chapter length which is 5min. Then on dvd options I see the heading and titles.Originally Posted by guns1inger
When I add all 13 it says Max is 8 video file so I guess I can only do 8 now and the other 5 on another dvd. Just need to know how to do the other settings so it comes out in good quality.
Sorry new to doing the multiple avis with FAV just need a little more help.
Thanks much -
Use media info or g-spot to tell you the running time of the video. Anything over 2 hours will start to cost you in quality. You can try half-D1 or VCD resolutions if you must put more than that on a disc, but the quality will still take a dive. 360MB usually implies 42 minute TV episodes, in which case I would put no more than 3 to a disc.
Read my blog here.
Ok thanks.
When you watch the dvd it is just one long show? I just put it in and I thought it would have a menu like 1,2,3 and I select.
So it just put's them in order I have them in FAVC? So if I do 1,2,3 they will be in order or if I want 3,2,5 it will play in this order?
merge multiple avi to 1 single file
By carlos28355 in forum Newbie / General discussionsReplies: 16Last Post: 2nd Oct 2010, 20:11 -
Multiple SUBs on AVI file?
By poumtatalia in forum SubtitleReplies: 1Last Post: 6th May 2010, 04:15 -
Multiple AVI files to multiple DVD discs, no quality loss, chapter per avi
By Delta007bhd in forum Video ConversionReplies: 11Last Post: 14th Apr 2010, 09:27 -
I'm new to Joining multiple avi files into one big file....
By Lahori82 in forum EditingReplies: 4Last Post: 29th Aug 2007, 14:05 -
How To Split Single DV AVI file into Multiple DV AVI files using Time Stamp
By insysnet in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 23rd Aug 2007, 13:49
