Hi guys
I've got what are probably very basic questions but I'm having a hard time finding out proper answers to them so I bow down to your collective knowledge
1. HD footage that has been captured on MiniDV tape, can that be transferred onto a computer HDD just using a normal MiniDV camcorder or does it have to support HDV? (I might be getting things a bit confused there!)
2. Is standard firewire 400 fast enough to transfer 1080i footage from a camcorder or does it need to be firewire 800?
3. Is HD footage from all the major manufacturers the same or are they different from company to company (am I right in thinking that I am asking if they are encoded with the same 'codec'?)
For example, if I had a Canon HV30, would I be able to put in a HD MiniDV tape from the equivilant Sony HD MiniDV camcorder and play back the footage?
4. If the answer to question three is 'no' does that mean I would have to buy a camcorder from each of the manufacturers to be able to view footage from each make of HD camcorder that takes tapes?
5. I have Adobe Premiere Pro CS3 (including Encore CS3), will that be able to read, edit and save to Blu-Ray disc each of recordings from different manufacturers camcorders?
Thank you very much in advance! As you can see I'm a bit confused with it all so any advice and pointing in the right direction would be most appreciated!!!
*Edit* - renamed the thread title as I realised it doesn't help give anyone reading what the thread is about - duh (sorry).
1) you need a HDV cam
2) firewire 400 is fine, HDV is the same bitrate as MiniDV
3) HDV is a standard like MiniDV
4) supposedly not.
5) iirc yes. cs4 for sure.
Digital camcorders that have analog pass-thru & TBC
By djnice in forum Capturing and VCRReplies: 30Last Post: 19th Jul 2020, 04:57 -
Capture AT&T (ATT) Uverse video signal & AT&T Uverse DVR programs
By bluehan2010 in forum Capturing and VCRReplies: 1Last Post: 23rd Apr 2010, 11:40 -
Newb B&W Film restore
By ctlw83 in forum RestorationReplies: 14Last Post: 25th Dec 2009, 11:14 -
capture & codec & HDV
By maxtrack in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 1st Apr 2009, 00:28
