i got my sons old pc an amd dual 2100 with vista with mce. it has a nvtv single card i don't have any manuals or cables. i want to convert from vhs to dvd. my old pc had an ati card and it worked fine. tried s video cable and audio from sima box but don't know how to get to it.
any and all help welcome
thanks
The S-Video connectors should allow video input. However, you will need software to view/record the video inputs.
If you know the manufacturer of the card, you can likely download the manual on their website.Google is your Friend -
its a nvidia nvtv card and i downloaded and installed the driver..
i'm missing something
thanks -
Model number of the card?
Here is the place to ask.
http://forums.nvidia.com/lofiversion/index.php?t339.htmlRecommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
The chipset is nVidia, but that chipset was used by multiple manufacturers.
The drivers are likely working just fine, but you need software to view the inputs and perform recording. It is likely already on the PC. But if you find the card manufacturer, you can likely go to their website and download it.Google is your Friend
What Capture software can I use with the NVIDIA NVTV PCI TV Turner card
By JAYEDIN in forum Capturing and VCRReplies: 3Last Post: 19th May 2009, 01:55 -
Sound only on first recording (NVIDIA NVTV)
By daralla in forum Capturing and VCRReplies: 0Last Post: 19th May 2009, 01:43 -
Capture card or Video card w/ capture tool
By joelson in forum Newbie / General discussionsReplies: 1Last Post: 11th May 2009, 11:45 -
Quality of a DVB/Tuner card ; but simplicity of a Capture card.
By BATGAL in forum Capturing and VCRReplies: 3Last Post: 1st Oct 2007, 11:51 -
Using Capture/Recoding PCI card - GV-650 Video Capture Card
By Confused Chimp in forum Capturing and VCRReplies: 1Last Post: 6th May 2007, 18:15
