I tried doing a search but wasnt able to find exactly whay I wanted. I have an avi file and a .sub&.idx file. I just want to create on avi file with the subtitles burned. I was able to preview it in mencoder, but the final file dosnt have the subtitles in it after I encode.
You have three options:
1/ Forget about the .idx/.sub, and find a matching .srt file on one of the subtitle search sites (1) (2).
2/ Put the AVI + .idx/.sub subtitles in a MKV container. If MKV isn't good enough for you (e.g. a stand-alone DVD/AVI player), then ffmpegX can transcode the MKV to AVI with burned-in subtitles, as BeardFan found out (1) (2).
3/ Or you can encode to DVD using the DVD mpeg2enc preset with Decode with mplayer activated. That seems to be the only setting that supports idx/sub for input in ffmpegX.
Adding subtitles to MKV file
By drgt in forum Newbie / General discussionsReplies: 8Last Post: 29th Dec 2010, 11:04 -
Creating my own subtitles and adding them to an AVI (divx) file? Best way?
By Chrushev in forum Newbie / General discussionsReplies: 1Last Post: 9th Jan 2010, 05:12 -
Adding subtitles to a BIG Avi file and then burn to dvd(?)
By Hal05154 in forum Newbie / General discussionsReplies: 5Last Post: 1st Apr 2008, 15:15 -
Adding Subtitles To An .AVI File
By thesal523 in forum SubtitleReplies: 2Last Post: 10th Aug 2007, 13:16 -
a problem with adding subtitles to avi file by autoGN
By 3l8x in forum Newbie / General discussionsReplies: 2Last Post: 16th Jun 2007, 02:28
