Hey all, I have Vista and have a DVD with menus I created all ready to go. If I click on "Make DVD" in the Architect software to either burn the dvd or prepare it, it comes up with this window box - "The selected folder is not valid. It is either not possible to create the folder or you do not have write access".
It will do this no matter what folder I try to put it in. I have used this program with my old pc with XP no problems. I assume it's a setting in my Vista. Any help? Thanks.
DVD Architect 3 is a pretty old version, and certainly pre-Vista. You might try compatibility mode and set it for XP SP2, but the real solution is to upgrade to a new version or try an alternate authoring tool that does run under Vista.
Read my blog here.
Any recommends on a good cheap one with lots of customizability? I need to be able to create multiple menus just like a "hollywood" style dvd.
GUIForDVDAuthor is free, which is about as cheap you can get.
It is not the tool, it is the planning and the time spent creating the assets that gets you the 'hollywood'style menu. That said, many studio menus are nothing to write home about.Read my blog here.
DVD Architect Languages problem
By Compo in forum DVD RippingReplies: 2Last Post: 23rd Jun 2011, 07:47 -
problem after problem - dvd architect, not enough room in temp files
By jgeck90 in forum Newbie / General discussionsReplies: 7Last Post: 1st Dec 2008, 04:35 -
sub-menu problem in DVD Architect Pro 4.5
By younso in forum Authoring (DVD)Replies: 9Last Post: 3rd Jul 2008, 17:51 -
AC3 problem in DVD Architect
By blackberryf1 in forum Authoring (DVD)Replies: 0Last Post: 1st Mar 2008, 10:25 -
DVD Architect Audio problem
By Just Mike in forum Authoring (DVD)Replies: 3Last Post: 12th Aug 2007, 02:11
