I have PowerDVD 8 installed on my system (running Windows XP).
I keep getting the dialog pop-up that says there is a patch that I need to download. I have did this once before and it caused all manner of problems (problems I didn't have before I patched).
I have now done a fresh re-install and need to know how to remove this annoying pop-up that prompts me to download the patch. There is no option in the settings menu itself so if I need to edit a system file, I'm willing to do that.
I have already tried just clicking on it and then not downloading the patch but the notice regenerates after awhile.
Thanks!
When you start power dvd 3 exe starts first set firewall such so none can connect to internet. Google for Autorun and sysinternals it is a microsoft website download and run Autorun (it is free), it shows everything that runs and starts on your computer then look under run section or just browse all of them and look for the publishers anything that is under Cyberlink belongs to power dvd uncheck all except powerdvd.exe Autorun is safe you can always go back and check things. Reboot and depending on your firewall/defense only allow powerdvd.exe and one help file that belongs to powerdvd to start. Run a movie make sure it works OK then you can rename those registration/update exe's. These kind of software they have spyware they continuously try to change your TCP ip parameters to bypass your internet security. Themselves don't call it spyware they offer!! you update and want to enhance your watching experience ...
Netflix problem anyone notice this?
By canadateck in forum Video Streaming DownloadingReplies: 6Last Post: 8th Oct 2011, 14:50 -
TMPGEnc Products - Notice Difference
By niteghost in forum Newbie / General discussionsReplies: 2Last Post: 21st Jul 2009, 20:15 -
PowerDVD Ultra - NO hard drive playback - latest patch
By joepic in forum Latest Video NewsReplies: 1Last Post: 26th Nov 2007, 15:44 -
Giving a 2 weeks notice
By DVinci in forum Off topicReplies: 3Last Post: 7th Sep 2007, 00:13 -
Update Notice Bug ?
By Spottedfeather in forum ffmpegX general discussionReplies: 0Last Post: 7th Aug 2007, 00:51
