    Jan 2009
    the show i recorded on my dvd recorder/player from my dvr will not play on my pc or other dvd players. does anyone know the reason for this or have any solutions?
    Jan 2009
    it will play on the dvd recorder i recorded it from
    Mar 2003
    Finalize the DVD in your recorder.
    Jan 2009
    what do you mean, fianlize it in the recorder. i didnt know there was that option?
    thank you
  5. Member Krispy Kritter's Avatar
    Jul 2003
    St Louis, MO USA
    Check the user manual. Recorders typically have two recording modes (VR & video), plus the discs also need to be finalized (as noted above) for use in other players.
    Google is your Friend
