Hi,
I have a folder of Alcohol 120% files (md0_auto file, MD1, MD2, MDF, MDS). It's a movie.
I would like to make a DVD5 to play in a standalone dvd player. When I use ImgBurn to create the dvd, ImgBurn makes a data dvd. The finished dvd has the same files as above. It won't play on a standalone, and it appears as blank dvd on a Mac even though it has data on it.
How can I convert the Alcohol 120% files into another format I can burn such as mp4, avi, mov, mpg, wmv? What other ways are available to be able to view the Alcohol 120% files as a DVD5?
Thanks in advance.
FYI: I'm using WinXP SP3 on a Mac running Parallels.
You should choose the "Write Mode" (CTRL + ALT + W).
Use DaemonTools for mounting a "virtual DVD" from the image file(s).What other ways are available to be able to view the Alcohol 120% files as a DVD5?
BTW, are you sure that that movie is a DVD-Video file set
(I mean, .IFOs, .BUPs and .VOBs)
Thanks for the responses. I used imgburn as you described, and I got the same result as I described above. The finished dvd won't play.
Midzuki. I don't have a DVD-Video file set. That's what I'm trying to create. I have a folder with the following files inside (md0_auto file, MD1, MD2, MDF, MDS). As I don't know the source of the files, it's possible that it's not what it claims to be.
I'm sure that I've been able to convert similar files in the past using visual hub. The results have varied but I've always converted the files into an actual video whether it's an mp4 or avi. This time nothing.
If anyone has any other suggestions, please let me know.
Thanks -
Copy the files from the folder that you got from the burn and mount them as described earlier,looks like someone made an image file of image files.
NERO7 HELP ! Burning 2 files to 1 dvd5
By rockonvidtrade in forum Authoring (DVD)Replies: 11Last Post: 12th Jun 2010, 02:13 -
Research finds many women need alcohol to enjoy sex
By zzyzzx in forum Off topicReplies: 0Last Post: 2nd Oct 2009, 15:52 -
Alcohol 120%
By orfajackson in forum Newbie / General discussionsReplies: 4Last Post: 29th Apr 2009, 13:59 -
Problem with Alcohol 120 mounting images on system start
By Talayero in forum ComputerReplies: 1Last Post: 29th May 2008, 12:53 -
Need advice on authoring XviD files to a DVD5
By alegator in forum Authoring (DVD)Replies: 9Last Post: 12th Jun 2007, 10:53
