Hi all,
I'm absolutely lost here. I bought the Sony Cybershot DSC T500, but I'm unable to play the recorded 720p HD video on my PC, it only plays it chopped. I was searching and searching, but I really don't understand anything at all. I don't know anything about computers. Was even unable to understand what is what when filling out the information about my PC when opening the account here. I have a Fujitsu Siemens Amilo Pi 2512 laptop.
I copied the information about the laptop from the website s I wouldn't know what's important to know for you. Any help and explaination in words as if you would explain to a kid is GREATLY appreciated!!!
Thanks a lot,
Jessica
Features
Great performance due to Intel’s mobile processor
technology with Intel® Pentium® Dual-Core processor
up to T2330 or Intel® Celeron® processor up to M540
Enjoy the crystal-clear picture quality of the 15.4” TFT
LCD WXGA display with BrilliantView technology
- High brightness
- Resolution of 1280 x 800
Get in contact with all your data via several interfaces
that connects to all your external peripherals
Get online when and where you want with integrated
Wireless LAN
Onboard graphic power with Intel® Graphics Media
Accelerator X3100
Store your data comfortably on the move with the built-in
DVD drive (Dual Double Layer with up to 8.5 GB
capacity)
Fast response times due to up to 2 GB DDR2 memory
Enjoy tranquility whilst writing e-mails, surfing the
Internet or watching your latest DVD due to the silent
mode functionality
Windows Vista® Home Basic or
Windows Vista® Home Premium and
application software
Data Sheet ½ Issue: March 2008 ½ AMILO Pi 2512 Page 2 / 3
Operating system1
or
Fujitsu Siemens Computers recommends
Optional application Software
Microsoft® Works
Vista DVD Playback Pack
Nero 7 Essentials CD/DVD burn software
Adobe Reader
Norton Internet Security Suite or Norman Anti-Virus
Country specific Internet Service Providers
Fujitsu Siemens Computers Recovery Program
Backup and restore the original status of the hard disk and
create system restore disks
or individual recovery media on CD or DVD are included
Manuals
Manual (on hard disk), quick start guide, safety guide,
warranty guide, recovery guide
Drivers
Updates downloadable at
http://www.fujitsu-siemens.com
System, processors, architecture
Chipset: Intel® 960GL + ICH8-M
CPU: Intel® Pentium® Dual-Core T2330 (1.6 GHz)
Intel® Celeron® M540 (1.86 GHz)
Memory
2 SO-DIMM memory slots
512 / 1024 MB memory modules
(533 MHz PC2-4200 / 667 MHz PC2-5300)
Up to 2048 MB DDR2 RAM
Storage devices/drives
HDD (SATA, 5400 rpm)
120, 160, 250 or 320 GB SATA hard disk
ODD:
Super Multi format DVD burner with double layer (DL)
support
Read speed: CD-ROM 24x, DVD-ROM 8x
Write speed: CD-R 24x, CD-RW 16x, DVD+R 8x,
DVD-R 8x, DVD+RW 8x, DVD-RW 6x,
DVD+R DL (8.5 GB) 4x,
DVD-R DL (8.5 GB) 4x, DVD-RAM 5x
Display
15.4” TFT WXGA BrilliantView technology
Resolution 1280 x 800
Brightness (typ.) up to 180 cd/m²
Contrast (typ.) up to 300:1
Compliance with standards
ISO 13406-2 class II
ACPI functions
S1 standby (LCD off)
S3 save to RAM
S4 save to disk
S5 complete off
Silent Mode
Graphics:
Intel® Graphics Media Accelerator X3100 PCI Express
graphic with up to 256 MB shared VGA memory2
(depending on configuration)
I/O Interfaces
3x USB 2.0 ports,
1x VGA,
1x modem, 1x LAN, 1x WLAN
1x ExpressCard slot (34/54 mm)
1x microphone in combined with 1x line in
1x headphone out combined with 1x S/PDIF digital out
1x power supply
1x 4-in-1 card reader SD/MS/MMC/MSPRO
Communications
Built-in 56 K, V.92 fax modem
10/100 Mbps LAN
Integrated Wireless LAN (WLAN) 802.11a/b/g:
- speeds up to 54 Mbps
- industry standard Wireless LAN security support
- wide range for in-house use
- WLAN on/off switch
For use in AT, BE, CZ, CY, DK, EE, FI, FR, DE, EL, HU,
IE, IT, LV, LT, LU, MT, NL, PL, PT, SK, SI, ES, SE, UK, IS,
NO, CH,
Results 1 to 9 of 9
Try play with the free VLC Media Player and see if it works better.
Also make sure you have installed all of the software that came with your camera. It may even include a special video player.
In addition to baldricks suggestion try media player classic or the high def version media player classic home cinema.Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
Movie file format is H.264 according to this
http://www.dpreview.com/news/0808/08082801sony_cybershot_dsc-t500.aspRecommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
MPCHC configured to use its internal h.264 decoder with 2 threads will probably play smoothly on that laptop:
MPCHC -> View -> Options -> Internal Filters -> H264/AVC (ffmpeg) -> Decoding Thread Number -> 2.
I don't know of that Intel graphics chipset supports DXVA (hardware h.264 decoding) but also try:
MPCHC -> View -> Options -> Internal Filters -> H264/AVC (DXVA) -> Decoding Thread Number -> 2. -
I've tried everything. With the VLC player the picture is very bad. I tried the Media Player Classic (jagabo, I don't understand your post sorry lol, didn't know how to download it, somehow managed to have it on my PC) I have sound, but the screen is black. Any other suggestions?
Understand that your laptop is very weak for playing this type of file.
VLC does not have a multithreaded h.264 decoder, and it doesn't support DXVA, so it won't play smoothly on your laptop.Originally Posted by jessica82
Note that MPCHC is not the same as MPC. MPCHC has support for h.264 video built in, MPC does not. If you installed MPC, uninstall it and install MPCHC instead. Then from MPCHC's menu bar select View -> Options. If the menu bar isn't displayed, right click on the main window and select Options.Originally Posted by jessica82
In the left hand pane of the Options dialog select Internal Filters. At the far right, in the Transform Filters area, make sure the little checkbox next to H264/AVC (FFmpeg) is checked. Then double click on that line to bring up the properties dialog for the FFmpeg decoder. Near the top of the dialog use the pulldown to set the "Decoding thread number" to 2. Press OK to exit that dialog. Press OK to exit the Options dialog. Exit MPCHC and restart it. It may now play your files smoothly.
If that doesn't work try enabling the H264/AVC (DXVA) decoder instead (disable the FFmpeg decoder). That will use your graphics cards h.264 decoder if it has one. If both work just use whichever one seems to work better.
Totally automated video clip editing
By SteveByrne in forum EditingReplies: 0Last Post: 29th Apr 2012, 02:12 -
I am totally lost and I know it Simple video titles, transitions?
By woodsy1 in forum Newbie / General discussionsReplies: 16Last Post: 25th Nov 2011, 12:43 -
My utube video quality IS LOST when Shrunk - HELP!!
By Entry in forum Video Streaming DownloadingReplies: 1Last Post: 4th Nov 2008, 22:55 -
LOST in the world of video on PC/TV
By sarainelkins in forum Video Streaming DownloadingReplies: 1Last Post: 6th Sep 2008, 18:10
