Hi,
I just got a Sony video walkman with 16gb of memory. I've tried to load a dvd video onto it in .mp4 format (which is what it says is required), but when I try to play the file on the device, it says that it cannot play because of incorrect file format. Any suggestions?
	I used the free Mediacoder http://www.mediacoderhq.com to convert any movie file to the MP4 format that my Sony Walkman NWZ-S710F requires. Here's what you have to do:
 1. Start Mediacoder and drag all the video files you want to convert to the list.
 2. Click on the Extensions icon on the toolbar. When it asks to use the online extensions, select No.
 3. On the window that pops up (from web browser) click on MP3/MP4 Players.
 4. Once that window opens up change Format to "MP4 (MPEG-4+AAC)" and click on Start to begin encoding.
 The converted files will be saved in the output folder that is selected in Mediacoder.
 You might want to change the following settings: Picture to 320x240 25 fps, and Quality to High Quality.
 For manual conversion you should use the following settings:
 Video:
 Format: MP4
 Bitrate: 384 or 512
 Resolution: 15, 25, or 30 fps
 Audio:
 Format: LC-AAC
 Quality: 80 or 100
 Container: MP4
 In Media Player Classic the output files have the following description:
 Video: MPEG4 Video 320x240 [GPAC ISO Video Handler]
 Audio: AAC 44100Hz stereo 3Kbps [GPAC ISO Audio Handler]
 The output file has the following description in MediaCoder:
 Container: MPEG-4; Bitrate: 391 Kbps
 Video: odivx; Bitrate: 384 Kbps; Resolution: 320x240
 Audio: AAC/AAC+; Bitrate: 128 Kbps (VBR); Sample Rate: 44100 Hz; Channel: 2
  AVI Video not playing in Sony Vegas 9.0c - looking for assistanceBy zargon33 in forum Newbie / General discussionsReplies: 1Last Post: 6th Apr 2010, 23:00
  DVD on Sony Walkman X, "SP" template but high bit rateBy dch888 in forum DVD RippingReplies: 1Last Post: 6th Dec 2009, 16:19
  Playing store purchased Blu-ray Movies - The Video and Audio stuttersBy orfajackson in forum Newbie / General discussionsReplies: 3Last Post: 10th Oct 2009, 02:28
  Sony PS3 now offers Video On Demand (Movies and TV shows)By FulciLives in forum Latest Video NewsReplies: 6Last Post: 24th Jul 2008, 23:13
  sony walkmanBy ruderenoxiii in forum Portable VideoReplies: 2Last Post: 1st Dec 2007, 01:33
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
