I need to convert some PAL XVID videos to NTSC DVD?
Which program/s should I use?
Thanks.
ConvertXToDVD is the most dependable for payware, or you could try FAVC for freeware, or maybe DVD Flick.
AviSynth + HcEnc to convert to 720x480 25 fps MPEG.
DgPulldown to add pulldown flags for 25 fps to 29.97 fps.
Whatever DVD authoring software you want to use. -
Isn't that what FAVC does?Originally Posted by jagabo
It first encodes to MPEG 720x480 and the uses DGPulldown. -
I don't use it. I don't know. But looking at the description it uses AviSynth, HcEnc, and DgPulldown -- so it's possible.Originally Posted by stanley_a
when Pal dvd has correct Ntsc audio (Pal>Ntsc conver)
By spiritgumm in forum Video ConversionReplies: 15Last Post: 13th Oct 2011, 13:57 -
Creating NTSC Blu ray DVD From PAL TS Files. need help with NTSC format
By Rick0725 in forum Authoring (Blu-ray)Replies: 0Last Post: 9th Apr 2009, 22:43 -
XVID/DIVX NTSC to PAL
By bilbonvidia in forum Video ConversionReplies: 14Last Post: 24th Jan 2008, 00:13 -
Quick question - PAL Menu when converting NTSC Xvid
By Azza_b in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 16th Oct 2007, 12:46 -
Is DivX(Xvid) A Cure For NTSC/PAL?
By hech54 in forum Newbie / General discussionsReplies: 9Last Post: 6th Aug 2007, 13:13
