Hello,
I was hoping someone could help me.
I want to put my DVD collection on my hard drive and was wondering what the best way of doing this is? I know very little about the process so please go easy on meI have some preferences although I am open to alternative suggestions.
1/ I want to compress (no more than 2gb per movie) so I can fit more on my hard drive but I don't want to lose too much picture & sound quality.
2/ The copies should appear as a single file with the file extension being flexible with various media players.
3/ To save on space, I am not bothered about keeping the extras / bonus features etc.
4/ If possible I would like to keep the chapters although if this means I am unable to reduce file size then I'm not too fussed.
I would be grateful for any suggestions on the best way to go about this.
Happy New Year to you all
Many thanks - Banrock
For simplicity's sake, you can keep it down to roughly 3 steps:
First, rip each DVD to your hard drive using DVDFab HD Decrypter (the free, ripping portion of the DVDFab tool).
Second, use AutoGK (also free) to convert each DVD title to an xvid avi file. This type of avi can give you the visual quality of your DVD at a fraction of the hard drive space. Sorry, but don't expect to keep chapter points.
Third, view the movies on VLC Media Player -- the best of the media players.
In the Tools section of this site, you will be able to find all of the free software mentioned. There are guides to go along with them. -
Thanks for the advice. I will give them a go. I have just evaluated fairuse which seems ok but it took 12 hours to run the process. Do all converters take this long? Is there a bit of software that runs the whole process and quickly?
If your computer details are correct, it will take a long time for conversions.
Doesn't matter much which program you use if they all use the same Xvid codec and settings.
DVD player to connect to a PC hard drive, or a networked hard drive?
By lifengwu in forum DVD & Blu-ray PlayersReplies: 0Last Post: 8th Oct 2010, 20:40 -
SATA, Hard Drive, Desktop only picking up part of the hard drive?
By Ghtpua in forum ComputerReplies: 9Last Post: 16th May 2010, 19:46 -
Sony Vaio with partitioned hard drive(Want full hard drive space on C)
By neworldman in forum ComputerReplies: 11Last Post: 17th Mar 2010, 14:42 -
DVDFAB Platinum 6 . . . no process for saving an ISO to the hard drive? :(
By MISS CHIEVOUS in forum Newbie / General discussionsReplies: 1Last Post: 10th Sep 2009, 10:44 -
Hard-Drive write caching,Is my hard drive faulty
By jezzer in forum ComputerReplies: 33Last Post: 27th Sep 2008, 12:06
