BETA BETA BETA BETA BETA BETA.Originally Posted by chrchr
Results 91 to 120 of 177
Have ffdshow, avisynth and AnyDVD. All lastest versions, downloaded tonight from this site. Using the LG GGW-H20L. All I get from BD Rebuilder is "Selected source is not BD format." Any clues???
Thanks. -
Sorry, nevermind. Dumb ass me got ahead of my self. Didn't install the software that came with the drive before trying to read Blu-Ray discs.
hey i just put new computer together and installed bdrebiulder and when i tried to run it i got this message component mscomctl.ocx or one of its dependencies not correctly registered a file is missing or invalid can anyone tell me how i might fix this problem
Do the back ups using bd builder work on ps3 yet? Last time i used it i wasted loadsa time trying to get this working. But it is only BETA stages so was wandering if there has been any fixes?
Finally, I made an playable BD shrunk movie to my SAMSUNG BD-P1400 player!
I use the following programs:
1. Avidemux 2.4 Qt4
2. AVIMux_GUI
3. mkv2vob
4. ImgBurn
THANK'S for your guide Baldrick and BitBurners.com
However i wonder...
Why a SIMPLE program for BD files similar (or better) to "DVD SHRINK" doesn't exist here?
A lot of people (and visits to your site) are waiting...
Thanks again! -
Hi all
My problem is trying to shrink a bd 50 down to a bd 25, i set up bd rebuilder to do a full backup, it seems to work fine doing the reencoding of these files in the stream screen of rebuilder
vid_00003 MPEG-4 (AVC), 1080p, 23.97fps 16.39 MB
vid_00017 MPEG-4 (AVC), 1080p, 23.97fps 19.18 MB
vid_00018 MPEG-4 (AVC), 1080p, 23.97fps 33.56 MB
ect ect and so on
but as soon as it tries to do the reencoding of this file it just hangs and goes no further
vid_00021 MPEG-4 (AVC), 1080i, 29.97fps 6,746.50 MB
any help in fixing this problem is well appricated -
Hi all
ect ect and so on
vid_00003 MPEG-4 (AVC), 1080i, 29.97fps 6,746.50 MB
please delete double post -
BD_Rebuilder v0.20.02
It doesn't recognize the AC-3 audio, again!
It doesn't matter how long , but please guys...
Fix it !
This is an IMPORTANT programme !!!
Thanks... -
maybe one day this program will actually be useful.
At this rate (approx 24 hours to compress BD to a DVD and with all these problems), it's a lot cheaper just to buy the original BDs.
"Half empty or half full, it's still only half a glass" - What Dave Says -
Just tried the new version of bd rebuilder BD-RBV02003 but still having the same problem with the same file, it does all the rest, but as soon as it get to this file it just stops and hangs and goes no further :
VID_21 MPEG-4 (AVC), 1080i, 29.97fps, 6,746.50 MB
This is the only 1080i file in the whole lot, is this the reson why? -
ANYBODY PLIS HELP ME.
[02:04:51] BD Rebuilder v0.20.02 (beta)
- Source: BODY_OF_LIES
- Input BD size: 25.50 GB
- Approximate total content: [02:08:18.273]
- Target BD size: 22.90 GB
- MOVIE-ONLY mode enabled
[02:04:52] PHASE ONE, Encoding
- [02:04:52] Extracting audio/subs [VID_00000]
- Error in attempt to extract audio/subs.
[02:04:52] - Failed to retrieve audio, aborted
WHY THIS HAPPEN. ANYBODY CAN TELL ME.
PLIS HELP ME EVERYBODY. HOW CAN DO THIS!!!!
1.bmp -
WHY BD REBUILDER ME NOT WORK PLIS SEE MY PICTURES. WHAT WRONG WITH THIS????
ANYBODY KNOW. PLIS TELL ME....
1.bmp -
veronica, you need to practice patience.
Bumping your post a few minutes later is a violation of our rules. Please wait a few days for a answer. Using "ALL CAPS' in a post will also get your post ignored by most of our members.
This is considered shouting and not a good idea if you want someone to respond.
Most Blu-ray discs have True HD audio, and you may need to convert that to AC-3 audio. Or select a different audio track. I don't know for sure, I don't use BD Rebuilder that often. You might want to look to the author for better information. He posts on the Doom9 forum most times. http://forum.doom9.org/showthread.php?t=143716
BD Rebuilder is a 'beta' program. That means it may not work for everyone. If you go to the Doom9 site, you may get better information about your specific problem.
I should add that not all Blu-ray discs are easy to work with. Some require a bit more knowledge. Have you tried other discs with the program? -
i couldn't find way to solve the problem inthat forum (doom9), anybody can help mefind the way to solve it?
You are in breach of the forum rules and are being issued with a formal warning. Please stop post same message/bump.
/ Moderator Baldrick -
first make sure that you have the latest versions of FFDShow and Matroska Splitter. personally i just install the latest K-Lite Codec Pack (Standard) and it takes care of all that. After the install, run "Video Decoder Configuration" for FFDSHOW from the "START/Programs" menu, and make sure MPEG2 decoding is enabled. also you need AVISYNTH 2.57 or newer. and try the newest version of BD-RB, v0.20.03.
for VC-1 encodes, have WMP11 installed, and in ffdshow have VC-1 disabled, so as to let WMP11 decode it.
some interlaced video sections do give BD-RB problems right now, the author is aware of this, but i think its mostly due to the inability for decoders to properly decode the video. the new nVidia decoders seem to work some people have said. -
rmeyers can you give me screen shoot your setting... i try your opini. but can't.
i have MPEG2 disabled because i have PowerDVD installed on my system, and i let that decode my mpeg2. otherwise, have it at libmpeg2, if that doesnt work, try libav.
but its saying that it fails to retrieve audio. hmm. maybe take a screenshot of the disc in BDInfo 0.52. BD-RB does have trouble with 7.1 sources at the moment. that could be the problem. -
rmeyers i try follow your setting but cannot work.
rmeyers do you know causes this:
[02:57:17] BD Rebuilder v0.20.02 (beta)
- Input BD size: 36.58 GB
- Approximate total content: [04:27:01.588]
- Resuming from previously started job.
[02:57:18] PHASE ONE, Encoding
- [02:57:18] Reencoding: VID_00000 (1 of 36)
- Encode failed. Retrying.
- Reached retry limit. Aborting.
[02:57:21] - Failed video encode, aborted
i have very much problem with this. can you help me?
whats normal priority and idle priority...should i set it at normal?
i got a blu-ray that has all 1080i and it crashes as soon as x264 starts up it does it on every verison of BD Rebuilder.
I've made 5 blu ray back-ups so far using bd rebuilder and all work on the ps3.Originally Posted by superhulk
[19:50:40] BD Rebuilder v0.20.02 (beta)
- Source: HELLBOY2_D1
- Input BD size: 41.72 GB
- Approximate total content: [04:29:18.650]
[19:50:40] PHASE ONE, Encoding
- [19:50:40] Extracting audio/subs [VID_00002]
- [19:50:42] Reencoding: VID_00002 (1 of 61)
- [19:52:02] Extracting audio/subs [VID_00009]
- [19:52:03] Reencoding: VID_00009 (2 of 61)
- [19:52:47] Extracting audio/subs [VID_00217]
- [19:52:50] Reencoding: VID_00217 (3 of 61)
- [19:55:41] Extracting audio/subs [VID_00220]
- [20:06:59] Reencoding: VID_00220 (4 of 61)
- [04:00:26] Extracting audio/subs [VID_00222]
- [04:00:37] Reencoding: VID_00222 (5 of 61)
- [04:09:16] Extracting audio/subs [VID_00269]
- [04:09:16] Reencoding: VID_00269 (6 of 61)
- [04:18:30] Extracting audio/subs [VID_00277]
- [04:18:33] Reencoding: VID_00277 (7 of 61)
- [04:21:01] Extracting audio/subs [VID_00278]
- [04:21:06] Reencoding: VID_00278 (8 of 61)
- [04:24:20] Extracting audio/subs [VID_00279]
- [04:24:22] Reencoding: VID_00279 (9 of 61)
- [04:26:30] Extracting audio/subs [VID_00280]
- [04:26:38] Reencoding: VID_00280 (10 of 61)
- [04:29:45] Extracting audio/subs [VID_00281]
- [04:29:49] Reencoding: VID_00281 (11 of 61)
- [04:31:46] Extracting audio/subs [VID_00282]
- [04:31:48] Reencoding: VID_00282 (12 of 61)
- [04:32:46] Extracting audio/subs [VID_00283]
- [04:32:47] Reencoding: VID_00283 (13 of 61)
- [04:33:18] Extracting audio/subs [VID_00284]
- [04:33:19] Reencoding: VID_00284 (14 of 61)
- [04:34:02] Extracting audio/subs [VID_00285]
- [04:34:04] Reencoding: VID_00285 (15 of 61)
- [04:34:28] Extracting audio/subs [VID_00286]
- [04:34:29] Reencoding: VID_00286 (16 of 61)
- [04:35:05] Extracting audio/subs [VID_00287]
- [04:35:06] Reencoding: VID_00287 (17 of 61)
- [04:36:11] Extracting audio/subs [VID_00288]
- [04:36:12] Reencoding: VID_00288 (18 of 61)
- [04:36:40] Extracting audio/subs [VID_00289]
- [04:37:09] Reencoding: VID_00289 (19 of 61)
- [04:55:38] Extracting audio/subs [VID_00291]
- [04:55:41] Reencoding: VID_00291 (20 of 61)
- [04:57:48] Extracting audio/subs [VID_00292]
- [04:57:56] Reencoding: VID_00292 (21 of 61)
x264.exe has encountered a problem and needs to close. We are sorry for the inconvenience.
why error?what's wrong with x264? anybody help me
anyone can explain to me why is this happened? -
been doing full disc copies for a while now using traxdata 25 gig discs no playback problems at all i wish there was support for true hd regarding full disc to dvd5 or dvd9 the ps3 shows them as data discs i havent had much luck trying to patch them also there doesnt seem much point in going from 43 odd gig to 8 gig the bitrate on the film would be well low
Hi all,
This seems to be my latest problem,
Trying to do a full backup with menus and all from a BD50 to a BD25.
Now the problem seems to be if the movie file is in seperate mt2s file (split) I can get it to reincode using the lastest version of bd_rebuilder but when burned and played it plays so much of the film and the it either locks up or jumps scenes.
I have none of these problems if the film is in just the 1 mt2s file, is there a way to fix this or a possible work around??
To Davie, I had the problem with the 1080i files, Make sure you have no other codex on your system and all the software you need to run bd_rebuilder correctly, These inclued the latest FFDSHOW and the Matroska splitter and AVISYNTH for it to work properly, this fixed the problem with the 1080i files for me -
Mr. chrchr can you pls explain to me how to solve this problem?
i dun understand the explanation in this forum???
DVD Shrink for Blu-Ray. anything like that out there?
By Bamahusker in forum Newbie / General discussionsReplies: 22Last Post: 9th Feb 2015, 21:39 -
How to quickly edit Blu-ray? Something like DVD Shrink or Nero Recode?
By peanutty in forum Authoring (Blu-ray)Replies: 8Last Post: 20th Nov 2011, 16:43 -
What is the difference between a Netwrok Blu-ray and Blu-ray DVD player?
By coody in forum DVD & Blu-ray PlayersReplies: 1Last Post: 4th Sep 2010, 22:04 -
Blu-Ray Program like DVD Shrink?
By PHNeedsHelp in forum Authoring (Blu-ray)Replies: 2Last Post: 30th Jul 2010, 08:18 -
Can I rip Blu Ray Discs with LG Super Multi Blu-ray Disc and HD DVD-ROM Dri
By donpato in forum Blu-ray RippingReplies: 5Last Post: 5th May 2008, 16:05
