I just bought an additional 1 Gig DDR2 for my wife´s Toshiba Satellite laptop. I asked for a 533 MHz and got a PC 4200 When I got home I ran CPU-Z and found out that the laptop has the PC 4300 type. Can I use the new memory or should I go and change it even if the 533 MHz speed is the same?. Thanx in advance and sorry if it´s a dumb question.
	try looking it up on a memory configurator. almost all the mem makers have them. like this one.
 http://www.corsairmemory.com/configurator/default.aspx
	I found this; perhaps it will help.
 http://www.overclock.net/other-hardware-mods/18119-ddr2-pc4200-vs-pc4300.htmlTHREADKILLER !
 References on File.
	Well, looks as though I've killed another thread !
 What have you found out about the memory compatibility, julitomg ?THREADKILLER !
 References on File.
	wtsinnc, sorry (you know...these days...), thanx for the link, I looked there and in other forums and without getting technical, the bottom line seems to be that for practical purposes they´re the same. I took the chance, installed it and woks perfectly...CPU-Z even describes the new memory as PC4300!
 minidv2dvd, yes I looked at the kingston site thanks, I looked up the specs for the different types of memory and helped me decide it was ok to mix them (as long as the "speed" was the same)
  Question on DDR2 RAMBy SE14man in forum Newbie / General discussionsReplies: 6Last Post: 5th Aug 2011, 08:01
  DDR2 and DDR3By Jomapil in forum ComputerReplies: 5Last Post: 18th Nov 2010, 03:35
  DDR and DDR2By Jomapil in forum ComputerReplies: 3Last Post: 18th Dec 2008, 07:50
  Can I mix different RAM types? (from old PC into new)By Rudyard in forum ComputerReplies: 5Last Post: 20th Nov 2008, 19:47
  Can an older Compaq Presario 6301RSH Desktop use PC4200 DDR2 RAM?By Denvers Dawgs in forum ComputerReplies: 3Last Post: 22nd Feb 2008, 00:27
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
 Quote Visit Homepage
				Visit Homepage
