    Dec 2008
    I was able to burn one DVD fine. Everything went well and I really liked the program. I decided to try burning another DVD. I restarted my PC, setup the chapters and titles and everything. I pressed convert, I came back sometime later and it was all done and ready to burn it to a DVD. I put in a new blank DVD, set the burn speed and pressed "OK". I waited a while, checking on it now and again. It seemed to be stuck at around 20% or so. I finally gave up on it and decided to try it all over again. I put in a new blank DVD, redid the converting and everything and told it to burn it to the DVD. I waited and it seemed to be stuck at around 17% forever. I gave up and decided to try burning to my harddrive as an ISO, so I set that and waited a bit. Again, it was stuck at around 17% forever.
  2. Member JonnyCabs's Avatar
    Oct 2006
    I can't give you the reason for this but will offer my setup as an answer.
    I never use the built-in burning software when i use this program.
    I opt for creating the vob files in a folder which i then burn using imgburn.
    I have never had a problem with this method, whilst the official forum is full of people with burning errors etc.
    Don't worry.......we'll be alright...
