I am working on a motion menu that I built in premiere.
It is really two seperate pieces where the first piece is like an interview and the second is a motion menu.
I would like the interview to play once then go to the motion menu and the motion menu would loop.
I first did it where the interview was set as a movie and then pointed the connection to the motion menu and the motion menu was set as loop and all the items pointed back to the motion menu. I have had some problems with DVDs understanding this so I was thinking of setting up the interview as cell 1 and then the motion menu as cell 2. I have the rendered the two clips either together or split. I set the first cell (interview) as link to the second cell (motion menu) the second cell is then set to loop.
First question: Am I on the right track
Second question: If I want to make buttons on the second cell how do I get it to show up in the menu screen. I can only see the first cell which is the interview which shouldn't have buttons. I can move around in the preview screen and see the second cell but that doesn't help me set my buttons in the right place.
Results 1 to 1 of 1
Tmpgenc dvd author 3 will not author my m2v files????
By biged670 in forum Authoring (DVD)Replies: 1Last Post: 28th Sep 2009, 12:10 -
Does Tmpg Divx Author encode or it only author ?
By BlackShadow90 in forum Authoring (DVD)Replies: 3Last Post: 29th Jul 2008, 04:56 -
Create DVD with TMPGEnc DVD Author 3 and not read on DVD Player
By Salutatous in forum Authoring (DVD)Replies: 1Last Post: 22nd May 2008, 11:22 -
Author 5.1 DVD
By Astrogirl in forum Authoring (DVD)Replies: 4Last Post: 7th Apr 2008, 16:43
