I see Drive there, but its Greyed out, and so is changer, cant ever click on them.
? hmm
Results 31 to 36 of 36
first select the drive you want to check in the destination box in the middle of the screen, there is a little drop down arrow next to the white box you click, and then slide over to the drive you want.
Write Capabilities
CD-R <Ticked
CD-RW<Ticked
Nothing Ticked for DVD In the Write Capabillities section. -
I think the recommendation to get a new drive in order to burn DVDs was sage advice.
UPDATE: Fixed Problem. Ended up being my DVD writer(or not dvd writer) that was the problem, only burned cds, not dvds. I went out and got a Very nice LG DVD burner.And Burned a movie onto a dvd-rw with success. Thank you for the help everyone.
BTW, I used ConvertXtodvd to convert and Burn the file.
And thank you Videohelp.com for the help, if I have any problems I will not hesitate to come back.
How to determine best quality when purchasing blank DVDs
By yznf in forum Newbie / General discussionsReplies: 14Last Post: 10th Feb 2012, 16:15 -
Burning files on DVDs
By carlmart in forum ComputerReplies: 3Last Post: 23rd Sep 2011, 11:46 -
Advice on blank DVDs
By didikai in forum Newbie / General discussionsReplies: 5Last Post: 28th May 2008, 23:30 -
problems burning movie file
By lynette00 in forum Newbie / General discussionsReplies: 4Last Post: 11th Jan 2008, 06:40 -
Burning DVDs of Bittorrent AVI files
By shadowcat in forum Newbie / General discussionsReplies: 4Last Post: 22nd Sep 2007, 08:16
