It turns out that my MS Windows Movie Maker (further - MM) saves an untrimmed clip (Save Movie menu) in DV-AVI format, instead of expected trimmed one.
The long story is as follows.
* A ripped DVD (a vob) was converted to a DV-AVI file (on a Mac, not sure which program, should not be relevant).
* It can be loaded into MM.
* It can be resaved again as a DV-AVI by MM
* It can be split in two or more clips, and the tail clip can be saved as a DV-AVI properly.
But the head clip of a split or trimmed/resized clip cannot be saved as intended in the DV-AVI format.
It saves, but so that only the sound track is trimmed, but the video goes all the way to the end of the original 'long' video.
It can be saved into other offered formats by MM, and that would be properly trimmed.
But the DV-AVI does not get trimmed!
Is there any workaround?
Please help!
Maxim Buyakov
AskMaxim.com: Russian/English Technical and Legal Translation, Voiceover
Results 1 to 1 of 1
Trying to edit a movie on windows movie maker (Canon Vixia HF R20)
By Classic in forum EditingReplies: 1Last Post: 8th Mar 2012, 13:07 -
Problems with Movie maker saving to dv-avi
By jbitakis in forum Video ConversionReplies: 7Last Post: 15th Sep 2010, 10:19 -
Windows Movie Maker crashes and won't puplish whole movie
By LoveMyslf in forum Video ConversionReplies: 27Last Post: 12th Dec 2009, 23:19 -
Can't import AVI into Windows Movie Maker
By tomchook in forum Video ConversionReplies: 4Last Post: 18th Apr 2009, 22:13 -
DV-AVI widescreen 16:9 movie from Windows Movie Maker.
By bagb in forum Newbie / General discussionsReplies: 19Last Post: 12th Nov 2007, 11:37
